Festool GRANAT delta abrasives are designed for efficient material removal and a consistently high‑quality finish. This version, sized specifically for Festool’s latest cordless delta sander, delivers excellent sanding performance while maintaining long service life, even on demanding surfaces.
The GRANAT abrasive is engineered for modern coatings and wood‑based materials, with a robust grit structure that resists clogging and maintains cutting performance for longer. Combined with Festool’s dust extraction system, it supports cleaner working conditions and improved surface visibility throughout the sanding process.
Suitable for Festool cordless delta sanders using the corresponding sanding pad size, including the latest Festool cordless delta sanding model DTSC200. Abrasive size 145 x 195mm
Supplied as a pack of Festool GRANAT delta abrasives ready for use with Festool StickFix sanding pads.
