This replacement spiral blade is designed for the HLC 82 planer, delivering exceptional planning quality for all common tasks. Its robust carbide construction ensures durability, while the spiral arrangement provides a pulling cut for a smooth, high-quality finish. Quick blade changes are simple with just three screws, and thanks to the precision fit, there’s no need to adjust blade protrusion - guaranteeing perfect true-running and consistent results.
Whether you’re planning solid wood, adjusting cornices, doors, or infill panels, or creating chamfers on beams and rebates on doors, this blade is built for accuracy and reliability. Compatible with HW standard planer blades at 82 mm width, it’s the perfect match for your Festool HLC 82 planer.
Supplied with: HW 82 SD spiral blade.
Manufacturer Part Number 577999
Web Attribute Set Power Tool Accessories
EAN Barcode 4014549436714
