{"product_id":"festool-jigsaw-blade-mixed-set-wood-metal-plastic-pkt-21","title":"Festool Jigsaw Blade Mixed Set Wood\/Metal\/Plastic (Pkt 21)","description":"\u003cp\u003eThe perfect all-rounder kit, Festool's versatile 21-piece jigsaw blade set is perfect for tackling a wide range of materials including wood, metal, and plastics. With five distinct blade types, you'll have the right tool for any job.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e5x Wood fine cut jigsaw blades S75\/2.5 5\/5\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eFine-toothed blades suitable for softwood and hardwood, coated chipboard and veneered blockboard, soft plastics and acrylic plexiglas. Produces precisely cut and splinter-free surfaces; conically ground teeth for clean cuts. 75mmx2.54mm, cutting depth 55mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e5x Wood universal jigsaw blades S75\/4 FSG\/5\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eUniversal blade for all relevant wood applications, HCS tool steel and cross-set teeth make it extra stable and very well suited for making straight, fast cuts. 75mmx4mm, cutting depth 30mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e5x Wood straight cut jigsaw blades S75\/2.8\/5\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eFor highly precise cuts in wood materials. The HCS tool steel has extremely sharp Japanese teeth so wood fibres are firstly scored, then cut through cleanly. 75mmx2.8mm, cutting depth 30mm.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e5x Metal steel\/stainless steel jigsaw blades HS75\/1.2 BI\/5\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eHigh-temperature- resistant and wear-resistant. Rippled basic form made from HCS bimetal, this saw blade is ideal for processing aluminium, non-ferrous metals and steel. 75mmx1.2mm, cutting depth 20mm.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e1x Plastics laminate jigsaw blade HM90\/3.3\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThis blade has an extremely long service life. The high-temperature-resistant and wear-resistant carbide saw blade is particularly well suited to laminate and melamine resin boards. 90mmx3.3mm, cutting depth 30mm.\u003c\/p\u003e\u003cp\u003eFinding the right blade is easy with Festool's color-coding system: yellow for wood, red for plastic, and blue for metal. Supplied in a reusable case.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118502498651,"sku":"110697","price":59.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/110697_xl.jpg?v=1789783162","url":"https:\/\/www.axminstertools.com\/products\/festool-jigsaw-blade-mixed-set-wood-metal-plastic-pkt-21","provider":"Axminster Tools","version":"1.0","type":"link"}
