{"product_id":"festool-kapex-ks-120-reb-260mm-mitre-saw","title":"Festool KAPEX KS 120 REB 260mm Mitre Saw","description":"\u003cp\u003eThe Kapex KS120 REB is compact and lightweight (only 21.5kg), but offers impressive cutting capacity and uncompromising accuracy. It is capable of cutting boards and panels up to 305mm wide and 88mm thick. Trimming crown mouldings up to 168mm in their original wall position does not present a problem.\u003c\/p\u003e\u003cp\u003eFestool have taken the concept of the slide compound mitre saw and redesigned it into a compact, portable machine. The following preset mitre angles are available; left: 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 30\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e; right: 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 30\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. A twin-line laser beam shows you precisely where the blade will cut. Variable speed means you can adapt to different materials for the best cutting performance.\u003c\/p\u003e\u003cp\u003eThe main casting provides a firm foundation to support the twin bars, which support the saw head giving the saw its supreme accuracy and solid feel in operation. Incorporated in the base are also small pull-out side extensions that provide extra support to longer workpieces.\u003c\/p\u003e\u003cp\u003eThe machine is supplied with a 60-tooth blade (2.5mm kerf), a work clamp and an adjustable bevel, which transfers angles for interior and exterior angles and dissects angles automatically for easy saw setting.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118330859867,"sku":"105629","price":1469.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105629_xl.jpg?v=1790104613","url":"https:\/\/www.axminstertools.com\/products\/festool-kapex-ks-120-reb-260mm-mitre-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
