This package deal comprises a Festool KAPEX UG-KS 60 Base Frame and Festool KA-UG-KS 60 Trimming Attachment; Left and Right
Festool UG-KS 60 Base Frame for KAPEX KS 60
With the UG-KS 60, you can turn your KAPEX KS 60 compound mitre saw into a complete mobile, mitre saw workstation. The combination is practical and robust resulting in portability with stability.
Attaching the KAPEX KS 60 to the base frame is very simple, and the mounting plate features convenient, safe storage for a spare saw blade. There is no need to remove the saw for transport; the saw and base are very compact when folded down. Two large diameter wheels make it easy to move the frame over rough surfaces or up kerbs or steps. The folding support frame doubles up as a handle for transporting the machine. Setup is extremely fast and easy, and levelling feet ensure complete stability on uneven ground. Once set up the working height is a comfortable 900mm.
These trimming attachments (or material support extensions) attach to the side of the UG-KS 60 base frame and KS 60 compound mitre saw combination. They are easy to mount and each has an adjustable support leg for levelling with the saw table. Each extension is 1,480mm long with a metric scale and adjustable length stop for repeat cuts. Their outstanding feature is a pullout telescopic extension, which allows for a full 2,400mm of support. The pullouts have clear measurement scales and end stops. These attachments make working with full-length boards a breeze; they are safe, convenient and accurate.
Manufacturer Part Number 202055
Web Attribute Set Mitre Saw Accessories Globale Group: low-margin-eu
