{"product_id":"festool-mfkc-700-eb-basic-cordless-edge-router-18v-body-only","title":"Festool MFKC 700 EB Basic Cordless Edge Router 18V (Body Only)","description":"\u003cp\u003eCordless edge routing made simple.\u003c\/p\u003e\u003cp\u003eSay goodbye to tangled cables and hello to freedom with the Cordless Module Edge Router MFKC 700. Designed for precision and versatility, this router lets you machine workpiece edges all the way around without the hassle of cords snagging. Its slim build, lightweight design and perfectly balanced centre of gravity ensure smooth, controlled routing every time. Plus, the innovative interface allows quick, tool-free swapping of router tables, so you’re ready for any edge job in seconds.\u003c\/p\u003e\u003cp\u003eThis router is compatible with all standard cutters up to 32 mm in diameter, thanks to the included 8 mm collet. The hard fibre base runner protects your workpiece from scratches while delivering effortless glide. With an adjustable RPM control and MMC Multi Material Control electronics, you can achieve scorch-free finishes across solid wood, acrylic and PVC edge veneers. The powerful, brushless EC-TEC motor ensures quiet operation and long-lasting performance, while integrated dust extraction and Bluetooth® battery connectivity keep your workspace clean and efficient.\u003c\/p\u003e\u003cp\u003eEnjoy easy depth adjustment accurate to 1\/10 mm, quick cutter changes via spindle stop, and a robust aluminium parallel side fence (available as an optional accessory) for perfect grooves and rebates. The 130 mm router table support guarantees spot-on results, while antistatic functionality and CLEANTEC dust extraction connections protect both you and your environment. Whether you’re chamfering, rounding, profiling or grooving, this cordless router delivers exceptional results with maximum convenience.\u003c\/p\u003e\u003cp\u003eSupplied with: SYS3 M 187 Systainer³, 8 mm Collet, Open-ended WAF 19 spanner.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118806946139,"sku":"113792","price":429.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113792_xl.jpg?v=1789792279","url":"https:\/\/www.axminstertools.com\/products\/festool-mfkc-700-eb-basic-cordless-edge-router-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
