{"product_id":"festool-mft-hz-80-lever-clamp-for-mft-mw1000","title":"Festool MFT-HZ 80 Lever Clamp for MFT \u0026 MW1000","description":"\u003cp\u003eWhether you call it a lever clamp, surface clamp, hold down clamp or bench clamp, the MFT-HZ 80 does its intended job perfectly. This cam action lever clamp allows you to secure workpieces on to the MFT and the MW1000 mobile workshop. It will fit into any 20mm dog hole in a multifunction workbench or track saw table.\u003c\/p\u003e\u003cp\u003eThe wide flat lever makes it simple to operate using one hand. Any workpiece; up to 80mm thick, round or flat can be securely clamped onto your bench top. This fast cam action surface clamp can be used anywhere you can drill a 20mm diameter hole. It is ideal for machining workpieces of any size and shape, for example when sanding, planing, drilling, gluing, etc.\u003c\/p\u003e\u003cp\u003eDimensions (L x W x H): 130 x 40 x 155mm, maximum height of workpiece: 80mm.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118444171611,"sku":"108325","price":43.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108325_xl.jpg?v=1789780390","url":"https:\/\/www.axminstertools.com\/products\/festool-mft-hz-80-lever-clamp-for-mft-mw1000","provider":"Axminster Tools","version":"1.0","type":"link"}
