The patented Multi-Jetstream2 pad guarantees outstanding sanding results thanks to its unique design.
Multi-Jetstream2 pad guarantees virtually 100% dust extraction for a consistently high material removal rate. These 150mm diameter Multi-Jetstream2 pads fit the Festool ETS150 sanders. They feature StickFix hook and loop system allowing quick and easy changing of abrasive discs.
These pads come in hard or soft and an ultra soft version. The hard pad has high edge solidity for plain surfaces and narrow edges. The heavy duty soft pad features high temperature durability for tough universal use. The ultra soft pad has an elastic structure for sanding rounded and contoured surfaces. Supplied as a single pad only.
