{"product_id":"festool-of-1010rebq-plus-router-with-led-light-1-4-230v","title":"Festool OF 1010REBQ-Plus Router with LED Light (1\/4\") 230V","description":"\u003cp\u003eFor power and accuracy, for easier, safer routing the Festool OF 1010 REBQ-Plus with LED Light, is in a class of its own. In a nutshell it is extremely versatile, excellently precise and very easy to handle.\u003c\/p\u003e\u003cp\u003eThe routing depth can be adjusted to the nearest tenth of a millimetre in seconds. The double-sided column clamp makes the router extremely torsionally rigid, guaranteeing perfect routing results.\u003c\/p\u003e\u003cp\u003eWith the rechargeable LED light ring around the working area, you can see the workpiece clearly and without any shadows. This is essential for achieving high accuracy in routing. This smart design lets you closely see the router cutter to improve your accuracy further.\u003c\/p\u003e\u003cp\u003eThis router allows easy one handed operation either with the Festool guide rail system or freehand.\u003c\/p\u003e\u003cp\u003eFestool's Plug-It system with its detachable power cable enables the fast swapping of Festool tools or easy cable replacement. The new style Festool parallel side fence is easily adjustable for quick and precise alignment, as the central clamp features a fine adjuster and adjustable guidance jaws, free of any tools.\u003c\/p\u003e\u003cp\u003eSupplied with 8mm and 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e collets, side fence, guide rail adapter, open ended spanner all packed in a Systainer SYS3 M 237 case.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118502596955,"sku":"110689","price":549.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/110689_xl.jpg?v=1789783186","url":"https:\/\/www.axminstertools.com\/products\/festool-of-1010rebq-plus-router-with-led-light-1-4-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
