Built to the highest standards, once again Festool have produced a router that will give the highest level of precision, and has powerful drive with low end torque giving the power needed to cut through even the hardest of materials with no jamming or tearing. The overall robust design and combination of features ensure easy handling, simple adjustments and a router that means business. Features include enormous cutter depth range of 80mm, quick height adjustment and an exact fine adjuster in 1/10mm steps with a zero function . Once set the lock on the handle clamps to both columns simultaneously for total accuracy. The innovative dust extraction system ensures that a very high level of waste is removed with a combination of extraction ring, chip catcher and exhaust adaptor . The extraction ring is cleverly controlled from the handle to allow you to view the cutter for position, then lowered for extraction. The spindle lock has a rocker and ratchet system for fast cutter changing and the base can be changed without tools. When used with a guide fence or a guide rail the rods are offset at 30 to the machine for easier guiding and working.
Supplied with 1/2 and 1/4 collet, 30mm guide bush, chip deflector and spanner in a Festool SYS M 337 SYSTAINER storage case and a whole kit of accessories packed in their own SYS M 237 SYSTAINER; guide rail adaptor set with base, parallel side fence with fine adjustment and clear extraction hood, guide rods, 17mm, 24mm, 27mm and 40mm copy guide rings, and 3 additional base plates; for guide bush with extraction, reduced opening 36mm and with extension support.
Collets Supplied 2026-02-01 00:00:00 +0000
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 98 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Motor Power 2,200 W
Cutter Speed 10,000 - 22,500 rpm
Manufacturer Part Number 574395
Voltage 230 V
Web Attribute Set Routers
EAN Barcode 5052511082124
