{"product_id":"festool-of1010-router-accessory-set","title":"Festool OF1010 Router Accessory Set","description":"\u003cp\u003eThe ZS-OF 1010 M Systainer is more than just a storage solution, this systainer streamlines your workflow and ensures that your tools are protected and ready to go!\u003c\/p\u003e\u003cp\u003eThe cleverly designed systainer contains versatile accessories, including guide rail adapters, copying rings, and base runners as well as space for your router cutters. All are held in designated spots, ensuring your tools and accessories are neatly organised and at your fingertips. Also included is a Micro Systainer SYS3 XXS, perfect for storing small materials, screws, and tiny components.\u003c\/p\u003e\u003cp\u003eWith the \u003cspecial id=\"22\"\u003e\u003c\/special\u003eGuide Rail Adapter\u003cspecial id=\"23\"\u003e\u003c\/special\u003e and support foot included, your router glides smoothly along guide rails, ensuring precise straight routing.\u003c\/p\u003e\u003cp\u003eNeed to create circles? The \u003cspecial id=\"22\"\u003e\u003c\/special\u003eTrammel Unit\u003cspecial id=\"23\"\u003e\u003c\/special\u003e allows you to route circles up to a diameter of 760 mm. Ideal for curved designs, decorative inlays, and circular patterns.\u003c\/p\u003e\u003cp\u003eThe \u003cspecial id=\"22\"\u003e\u003c\/special\u003eFine Adjuster\u003cspecial id=\"23\"\u003e\u003c\/special\u003e feature lets you dial in the perfect settings for both the guide rail adapter and the trammel unit. Achieve pinpoint accuracy in your woodworking projects.\u003c\/p\u003e\u003cp\u003eThe \u003cspecial id=\"22\"\u003e\u003c\/special\u003eTransparent Base Runner\u003cspecial id=\"23\"\u003e\u003c\/special\u003e provides an unobstructed view of your workpiece. No more guesswork—see exactly where your router is cutting, even in intricate designs.\u003c\/p\u003e\u003cp\u003eThe Wide Base Runner ensures steady guidance along edges. Whether you’re working on tabletops, cabinetry, or custom moldings, your router stays on track.\u003c\/p\u003e\u003cp\u003eDifferent \u003cspecial id=\"22\"\u003e\u003c\/special\u003eCopying Rings\u003cspecial id=\"23\"\u003e\u003c\/special\u003e allow reliability when routing with templates. The copying rings are precisely centred in the router’s base plate using the centring mandrel, achieving consistent results every time.\u003c\/p\u003e\u003cp\u003eThe unique \u003cspecial id=\"22\"\u003e\u003c\/special\u003eChip Deflector\u003cspecial id=\"23\"\u003e\u003c\/special\u003e optimizes dust extraction when routing along edges for dust free routing And with Parallel Side Fence compatibility the extraction hood pairs seamlessly with the parallel side fence, ensuring dust-free operation and precise cuts.\u003c\/p\u003e\u003cp\u003eFrom precision routing to seamless storage, the ZS-OF 1010 M Systainer is an intelligently designed system you can't live without.\u003c\/p\u003e\u003cp\u003eSupplied with: Guide Rail Adapter, Fine Adjuster Fe-Fs\/Of 1000, Centring Mandrel , Copying Ring D17, Copying Ring D24, Copying Ring D27, Copying Ring D30, Copying Ring D40, Base Runner Las-Of 1010 R, Support Afb-Of 1010 R, Trammel Unit Sz-Of 1000, Extraction Hood For Of 1010 R Parallel Side Fence, Chip Deflector, Systainer Sys3 Xxs 33, Systainer Sys3 M 187.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118502236507,"sku":"110690","price":253.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/110690_xl.jpg?v=1789783131","url":"https:\/\/www.axminstertools.com\/products\/festool-of1010-router-accessory-set","provider":"Axminster Tools","version":"1.0","type":"link"}
