The ZS-OF 1010 M Systainer is more than just a storage solution, this systainer streamlines your workflow and ensures that your tools are protected and ready to go!
The cleverly designed systainer contains versatile accessories, including guide rail adapters, copying rings, and base runners as well as space for your router cutters. All are held in designated spots, ensuring your tools and accessories are neatly organised and at your fingertips. Also included is a Micro Systainer SYS3 XXS, perfect for storing small materials, screws, and tiny components.
With the
Need to create circles? The
The
The
The Wide Base Runner ensures steady guidance along edges. Whether you’re working on tabletops, cabinetry, or custom moldings, your router stays on track.
Different
The unique
From precision routing to seamless storage, the ZS-OF 1010 M Systainer is an intelligently designed system you can't live without.
Supplied with: Guide Rail Adapter, Fine Adjuster Fe-Fs/Of 1000, Centring Mandrel , Copying Ring D17, Copying Ring D24, Copying Ring D27, Copying Ring D30, Copying Ring D40, Base Runner Las-Of 1010 R, Support Afb-Of 1010 R, Trammel Unit Sz-Of 1000, Extraction Hood For Of 1010 R Parallel Side Fence, Chip Deflector, Systainer Sys3 Xxs 33, Systainer Sys3 M 187.
