The Festool PSBC 500 Circular Core Marker Set is a versatile jigsaw accessory designed to make accurate circular cuts, semicircles and curved shapes easier to achieve. Compatible with the Festool PSC 500 and PSBC 500 cordless jigsaws, it enables precise circular cut-outs ranging from 3m to 92mm in diameter. The stable guiding system helps maintain consistent cutting accuracy, making it ideal for producing clean, uniform shapes in woodworking and furniture-making applications.
The set comprises the KS-PSC 500-Set circle cutter and the LAS-KS-PSC 500 base runner, which allows the circular cutting attachment to be quickly and easily fitted to the compatible jigsaw base. Designed for straightforward setup and controlled operation, it provides reliable guidance when cutting circles, semicircles and sweeping curves.
Web Attribute Set Cordless Jigsaws
EAN Barcode 4014549482728
