{"product_id":"festool-rotex-ro-150-feq-plus-sander","title":"Festool ROTEX RO 150 FEQ-Plus Sander","description":"\u003cp\u003eThis RO150FEQ Rotex sander from Festool is more powerful, economical and ergonomic and few other sanders offer such control and high finish. Rotex was the very first geared eccentric sander and set ground-breaking standards with its innovative 3-in-1 principle. Coarse sanding, fine sanding or polishing, it does the work of three tools. The powerful motor and long life gear unit gives high performance under load, fitted with an MPE \u003cspecial id=\"2\"\u003e\u003c\/special\u003eMULTI-JETSTREAM 2\u003cspecial id=\"2\"\u003e\u003c\/special\u003e sanding backing pad.\u003c\/p\u003e\u003cp\u003eThe  MULTI-JETSTREAM 2 pad works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result  is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment.  Made from MPE high tear resistant material the pad is also very durable.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with MPE sanding base (soft), edge protector and Systainer\u003cspecial id=\"9\"\u003e\u003c\/special\u003e T-LOC SYS3 storage case.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54116275880283,"sku":"571592","price":659.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/571592_xl.jpg?v=1790104846","url":"https:\/\/www.axminstertools.com\/products\/festool-rotex-ro-150-feq-plus-sander","provider":"Axminster Tools","version":"1.0","type":"link"}
