Festool
Festool RSC 18 EB-Basic Reciprocating Saw 18V (Body Only)
SKU: 109584
£363.98
£303.32 Excl. VAT
  • Powerful, fast, robust and thoughtfully designed
  • Tool-free blade changing; blade can be rotated by 180
  • Pendulum action for fast progress
  • Large variable speed trigger for easy control
  • Maintenance free brushless EC-TEC motor
  • Low vibration increases control and reduces fatigue
  • Integrated LED lights the area around the blade
  • Supplied with dust extraction adaptor
  • Fits neatly into Systainer along with all accessories
The Festool RSC 18 cordless sabre saw (aka reciprocating saw) is everything a professional wants from this type of tool. Powerful, fast, robust and with thoughtfully designed positive features .
The large variable speed trigger offers easy control over the stroke rate and smooth start-up.You can switch between a normal reciprocating stroke or pendulum action at the flick of a switch.
The brushless EC-TEC motor is maintenance free and offers a long trouble free service life. The RSC 18 features low vibration, which increases control and reduces fatigue.
Blade changing is simple and tool-free. On release the chuck ejects the blade, so there is no need for you to touch the sharp teeth or a hot blade. The saw blade can be rotated by 180, allowing you to choose the best angle of attack for the job. The integrated LED lights the area around the blade so you can see the cut’s progress.
The RSC 18 comes with a clip-on dust extraction adaptor, when connected to a suitable extractor it offers virtually dust-free working. If you use Bluetooth® battery packs you can switch the extractor on remotely.
The RSC 18 fits neatly into the Systainer along with all the necessary accessories, everything is kept together, safe and easily accessible.
Supplied with: RSC-AV dust extraction adaptor, 230mm Universal bi-metal woodcutting blade and Systainer3 SYS3 L 187.
Note: this is a body only tool, supplied without batteries or charger.
Battery Voltage 18 V
Rating Trade/Professional
Stroke Length 32 mm
Sound Power Level LwA [Uncertainty K] 98 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 10.8 m/s² [1.5 m/s²]
Manufacturer Part Number 576947
Web Attribute Set Cordless Sabre Saws
EAN Barcode 4014549389072
