{"product_id":"festool-sanding-block-80-x-130mm-with-extraction-outlet","title":"Festool Sanding Block 80 x 130mm with Extraction Outlet","description":"\u003cp\u003eThe Festool Sanding Block 80 x 130mm with Extraction Outlet is a practical hand sanding accessory designed to deliver clean, controlled sanding results while helping to minimise airborne dust. Combining ergonomic handling with integrated dust extraction capability, this tool is ideal for fine sanding, surface preparation and finishing tasks across a wide range of materials when fitted with the appropriate abrasive grit for the application.\u003c\/p\u003e\u003cp\u003eDesigned for use with Festool abrasives and dust extractors, the sanding block features an integrated extraction outlet that removes dust directly from the sanding surface, helping to create a cleaner working environment and improving visibility during sanding. Its compact size provides excellent control for detailed work, edge preparation and surface finishing tasks. Measuring 80 x 130mm, the sanding block is suitable for sanding wood, painted surfaces, fillers, lacquers and composites. The lightweight, ergonomic design remains comfortable during prolonged use, while efficient dust extraction helps reduce clean-up time and abrasive clogging.\u003c\/p\u003e\u003cp\u003eIdeal for joiners, furniture makers, decorators, finishers and woodworking enthusiasts, the sanding block is well suited to preparation, intermediate sanding and final finishing applications. Compatible with Festool abrasives and dust extraction systems, providing an effective solution for cleaner and more efficient manual sanding.\u003c\/p\u003e\u003cp\u003eSupplied as set with bypass adaptor, Festool hose adaptor, 6 sheets of Granat abrasive 2 each; P80, P120 and P180 and a protection pad.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54514853183835,"sku":"114803","price":54.55,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114803_xl.jpg?v=1792675844","url":"https:\/\/www.axminstertools.com\/products\/festool-sanding-block-80-x-130mm-with-extraction-outlet","provider":"Axminster Tools","version":"1.0","type":"link"}
