The Festool Fine‑Cut saw blade is designed for clean, accurate and splinter‑free cuts when working with cordless plunge‑cut saws. With a slim 1.6 mm kerf, this blade significantly reduces cutting resistance, helping to extend battery runtime while allowing faster, more efficient work progress.
Manufactured from high‑quality steel and fitted with fine‑grain carbide teeth, the blade delivers consistent cutting performance and long service life. The specially developed tooth geometry uses grouped toothing to produce smooth, precise results across a wide range of wood‑based materials. Whether trimming panels or making fine cross‑cuts in solid wood, this blade is engineered to match the performance demands of Festool cordless saws.
This saw blade has a diameter of 160 mm, a cutting width of 1.6 mm and a bore size of 20 mm. It is manufactured from hardened steel and fitted with precision‑ground fine‑grain carbide teeth, designed specifically for cordless plunge‑cut saw applications.
Compatible with Festool 160 mm plunge‑cut saws, including the HKC 55 K, TSC 55 K, TSC 55 KS and TS 55 models, and suitable for use on Festool guide rails. The thin‑kerf design makes it particularly well‑suited to Festool cordless saws where efficiency and runtime are critical.
Ideal for fine cross‑cuts in solid wood, veneered and coated panels, MDF and furniture panels. Well suited to furniture making, kitchen fitting and precise panel cutting tasks.
Blade Diameter 160 mm
Manufacturer Part Number 578586
Teeth 25
EAN Barcode 4014549453285
