Festool
Festool Spiral Upcut Router Cutters
SKU: 930610
£26.18
£21.82 Excl. VAT
  • High-speed steel spiral cutters
  • Very clean cut
  • Better plunge cutting
  • Less wear and tear on router
  • Faster feed rates possible
  • 8mm shank
This range of Festool spiral cutters in HSS is suitable for many applications. Spiral cutters offer a superior finish with higher possible feed rates due to excellent chip clearance. Twin flutes ground around the body of a spiral bit help eliminate vibration by spreading the cutting action over a longer edge. With their drill-like points, spiral upcut bits are also better for plunge cuts, decreasing the likelihood of burning the work.
Manufacturer Part Number 490945
Shank Diameter 8 mm
X = Depth of Cut 19 mm
D = Overall Diameter 8 mm (5/16")
Web Attribute Set Spiral Router Cutters D: 8 X: 19
EAN Barcode 4014549000373
