The Festool Splinter Guards for PSE 18 Jigsaws are replacement cutting accessories designed to help reduce tear-out and improve cut quality when working with timber, veneered boards and laminated materials. They provide cleaner cutting results and help minimise finishing work after cutting.
Designed for use with compatible Festool PSC-E18, PSC500 and PSBC500 jigsaws, the splinter guards support the material directly adjacent to the blade, helping prevent fibres from lifting during the cutting process. This results in cleaner edges and improved surface finish.
Simple to fit and replace, the splinter guards help maintain optimum cutting performance across a wide range of woodworking applications. Their compact design ensures minimal impact on tool handling and visibility.
Ideal for joiners, cabinet makers and furniture manufacturers, these splinter guards are particularly useful when working with visible finished surfaces.
Supplied as a pack of 5 splinter guards.
