{"product_id":"festool-sys3-m-137-fs-2-set-guide-rail-accessory-set","title":"Festool SYS3 M 137 FS\/2-Set Guide Rail Accessory Set","description":"\u003cp\u003eAll the items contained within the Systainer 3 will help you realise the full potential of your Festool guide rail. Everything that can make using the guide rail even better is here, organised in one Systainer 3: An Angle Stop, Kickback Stop, Guide Rail Connectors, Deflector and Guide Rail Clamps.\u003c\/p\u003e\u003cp\u003eThe Angle stop attaches quickly and securely without tools to your guide rail, allowing precise cuts of angles from -60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to +60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003eIncreased safety with the Kickback Stop. It functions as a limit stop or secures the circular saw against kickbacks when plunging into the workpiece.\u003c\/p\u003e\u003cp\u003eGet connected, the guide rail connectors join and align two guide rails perfectly, as if they were one single piece.\u003c\/p\u003e\u003cp\u003eThe Deflector clips onto the end of your rail and prevents the vacuum hose and cable from snagging on the end of the rail.\u003c\/p\u003e\u003cp\u003eThe Guide Rail Clamps are designed to slide into the groove on the underside of the guide rail and secure the rail without causing an obstruction.\u003c\/p\u003e\u003cp\u003eSmart accessories make working with the guide rail even easier and more efficient.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118444237147,"sku":"108324","price":236.48,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108324_xl.jpg?v=1789780399","url":"https:\/\/www.axminstertools.com\/products\/festool-sys3-m-137-fs-2-set-guide-rail-accessory-set","provider":"Axminster Tools","version":"1.0","type":"link"}
