An addition to the Festool Systainer range, this cantilever tool box ensures you can store and have all sorts of sundry items to hand. It is fitted with individually removable plastic containers which can be rearranged to suit. Strong and durable, it gives you a simple solution to having items such as screws and other fixings organised and ready to use. The cantilever design means there is storage in the base as well as 2 top side trays. You can connect other Festool Systainers to the bottom of this toolbox. Supplied with storage boxes all 71mm in height, 2 x 60 x 60mm , 2 x 60 x 120mm and 1 x 180 x 120mm.
Overall L x W x H 396 mm x 296 mm
Manufacturer Part Number 499901
Web Attribute Set Power Tool Cases
EAN Barcode 4014549207628
