These Festool 160mm diameter (20mm bore) blades are compatible with the TS55F, HK55 and HKC 55 models as well as other saws taking this size of blade. The tungsten carbide tips have an alternate bevel grind coupled with a kerf of only 1.8mm, giving a rapid, clean cut. These features minimise the amount of power required for a given cutting operation. This 18-tooth blade makes a good general purpose blade for wood or plastics.
Festool
Festool TCT Saw Blade - 160mm x 1.8mm x 20mm 18T
| Blade Diameter | 160 mm |
| Maximum RPM | 9,500 rpm |
| Manufacturer Part Number | 500458 |
| Kerf | 1.8 mm |
| Teeth | 18 |
| Tooth Format | ATB |
| Plate Thickness | 1.2 mm |
| Hook Angle | 25 |
| Bore Size | 20 mm |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549223598 |
