These 254mm (10”) blades fit the Festool TKS 80 sawbench, but can of course fit any saw that takes this size of blade.
This 60 tooth crosscut blade produces clean splinter-free cuts. The tooth format and cutting angle is particularly suitable for cutting veneered boards, parquet, hard plastics, hard PVC, solid wood cross cuts, blockboard, plywood, multiplex/multi-layered wood, acrylic glass and MDF.
Festool TCT (tungsten carbide tipped) circular saw blades offer a perfect combination of cutting performance and quality results. The blades feature colour coding for easier selection of the correct saw blade.
Blade Diameter 254 mm
Maximum RPM 4,500 rpm
Manufacturer Part Number 575976
Kerf 2.4 mm
Teeth 60
Tooth Format ATB
Plate Thickness 1.8 mm
Hook Angle 10
Bore Size 30 mm
Web Attribute Set Circular Saw Blades
EAN Barcode 4014549351413
