A 160 x 20mm Festool saw blade suitable for the TS55 plunge saw, with a 2.2mm kerf. This blade has 48 teeth with a triple chip grind giving you a fine cut on laminate costed boards, HPL (High Pressure Laminate) melamine resin boards (Trespa ®), mineral materials, acrylic glass and phenolic-resin-bonded fibre and fabrics.
Blade Diameter 160 mm
Maximum RPM 9,500 rpm
Manufacturer Part Number 496308
Kerf 2.2 mm
Teeth 48
Tooth Format TCG
Plate Thickness 1.6 mm
Hook Angle 4
Bore Size 20 mm
Blade Application Laminate Board (48 teeth)
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549120583
