{"product_id":"festool-tct-saw-blade-universal-168mm-x-1-8mm-x-20mm-28t","title":"Festool TCT Saw Blade Universal 168mm x 1.8mm x 20mm 28T","description":"\u003cp\u003eThis high tech, high spec blade ensures the job gets done faster and with a better result. These new generation of thin kerf saw blades are designed to give maximum performance. The 1.8mm thin kerf saw blade and tooth geometry allows you to work faster, reduces the load on the machine.\u003c\/p\u003e\u003cp\u003eThe blade teeth are high-quality carbide resulting in a long service life. The tooth format is alternate bevel (ATB) is designed for best results when cutting solid wood, blockboard, plywood, chipboard, MDF etc.\u003c\/p\u003e\u003cp\u003eThese blades fit the Festool TS 60 plunge-cut saws and the CSC SYS 50 Table Saw.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118466486619,"sku":"109094","price":44.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109094_xl.jpg?v=1789781245","url":"https:\/\/www.axminstertools.com\/products\/festool-tct-saw-blade-universal-168mm-x-1-8mm-x-20mm-28t","provider":"Axminster Tools","version":"1.0","type":"link"}
