210 x 30mm Festool saw blades suitable for the TS75 plunge saw. A general purpose medium cutting blade with 36 teeth, 2.4mm kerf.
Blade Diameter 210 mm
Maximum RPM 6,500 rpm
Manufacturer Part Number 493198
Kerf 2.4 mm
Teeth 36
Tooth Format ATB
Plate Thickness 1.8 mm
Hook Angle 15
Bore Size 30 mm
Blade Application General Purpose (36 teeth)
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549044964
