These 254mm (10) blades fit the Festool TKS 80 sawbench, but can of course fit any saw that takes this size of blade.
This 40 tooth universal blade produces fast, clean cuts. The tooth format and cutting angle is particularly suitable for cutting solid wood cross cuts, blockboard, plywood, multiplex/multilayered wood, raw chipboard, MDF (medium-density fibreboard) and HDF (high-density fibreboard).
Festool TCT (tungsten carbide tipped) circular saw blades offer a perfect combination of cutting performance and quality results. The blades feature colour coding for easier selection of the correct saw blade.
Blade Diameter 254 mm
Maximum RPM 4,500 rpm
Manufacturer Part Number 575975
Kerf 2.4 mm
Teeth 40
Tooth Format ATB
Plate Thickness 1.8 mm
Hook Angle 15
Bore Size 30 mm
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549362723
