160 x 20mm Festool saw blades suitable for the TS55 plunge saw, all with a 2.2mm kerf. There are a range of blades available; general purpose medium cutting blade with 28 teeth, ‘Panther’ for faster cutting with less force when rip cutting 12 teeth, fine cut, veneered and coated panels, solid wood, MDF 48 teeth, and a fine cut 52 tooth blade for aluminium panels and profiles, hard and fibre reinforced plastics.
Blade Diameter 160 mm
Maximum RPM 9,500 rpm
Manufacturer Part Number 496301
Kerf 2.2 mm
Teeth 48
Tooth Format ATB
Plate Thickness 1.6 mm
Hook Angle 5
Bore Size 20 mm
Blade Application Fine (48 teeth)
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549017593
