{"product_id":"festool-tct-saw-blades-thin-kerf-160mm-x-1-8mm-x-20mm","title":"Festool TCT Saw Blades Thin Kerf - 160mm x 1.8mm x 20mm","description":"\u003cp\u003eThese high tech, high spec blades ensure the job gets done faster and with a better result - a new generation of thin kerf saw blades, designed to give maximum performance. The 1.8mm thin kerf saw blades and tooth geometry allows you to work faster, reduces the load on the machine and, in the case of cordless tools, extends battery runtimes.\u003c\/p\u003e\u003cp\u003eThe blade teeth are high-quality carbide resulting in a long service life. There are blades for different applications, each with the tooth format required to achieve a perfect cut.\u003c\/p\u003e\u003cp\u003eThese blades fit the Festool TS 55 F and TSC 55 K plunge-cut saws, as well as the HK 55 and HKC 55 portable circular saws\u003c\/p\u003e\u003cp\u003ePlease note these do not fit Festool TS55R or other previous models, as these take 2.2mm kerf blades.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Fine (42 teeth)","offer_id":54163355992411,"sku":"107886","price":57.88,"currency_code":"GBP","in_stock":true},{"title":"Laminate Board (52 teeth)","offer_id":54163356025179,"sku":"107887","price":84.98,"currency_code":"GBP","in_stock":true},{"title":"Universal (28 teeth)","offer_id":54163356057947,"sku":"107888","price":44.98,"currency_code":"GBP","in_stock":true},{"title":"Rip (12 teeth)","offer_id":54163356090715,"sku":"107889","price":33.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107886_xl.jpg?v=1790105145","url":"https:\/\/www.axminstertools.com\/products\/festool-tct-saw-blades-thin-kerf-160mm-x-1-8mm-x-20mm","provider":"Axminster Tools","version":"1.0","type":"link"}
