The rear take off adds an extra dimension to your TKS 80 saw table. By adding an extra 580mm at the back of the saw it makes machining long sheet material or ripping planks a safer and controllable operation. The rear extension table is quick and easy to assemble and adjust. Disassembly is equally easy for transportation.
Manufacturer Part Number 575825
Web Attribute Set Saw Bench Accessories
EAN Barcode 4014549343340
