The combination of Festool’s TS 60 plunge saw and the Festool 1,400mm Guide Rail creates a superb system for cutting sheet material with spot-on accuracy.
The TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. A unique anti kickback system, protects you from injury and damage to your work. A transparent sliding viewing window and additional markings provide a view of the blade’s start and end point, prior to making a plunge cut. Dust extraction is highly effective when connected to a suitable extractor. With the latest generation brushless EC-TEC motor, the TS 60 is compact, virtually maintenance-free and powerful. Fitted with a thin kerf saw blade, the high speed 6,800 rpm EC-TEC motor ensures quick results.
The TS 60 is fully compatible with Festool FS guide rails and FSK cross cut rails, offering 57mm cutting depth with rail fitted.
The guide rail has two PTFE strips to allow the saw tool to glide smoothly on the rail. On the underside of the rail there are two neoprene strips, which prevent slippage. There is also a special rubber strip on the underside which is used to minimise splintering on the top surface.
The TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. Supplied with a 1,400mm guide rail the TS60 can also be attached to the optional cross cut rails. Blade supplied is a 168mm x 1.8kerf x 20mm bore with 42 Teeth.
Bevel Angle Range -1 to +47
Dust Extraction 27 mm / 36 mm Outlet
Max Depth of Cut @ 45º 45 mm
Max Depth of Cut @ 90º 62 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 168 mm
Sound Power Level LwA [Uncertainty K] 101 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 90 dB(A) [3.0 dB]
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Saw Blade Speed 3,000 - 6,800 rpm
Manufacturer Part Number 576724 & 491498
Web Attribute Set Plunge Saws
EAN Barcode 5052511130771
