{"product_id":"festool-ts-60-kebq-plus-fs-plunge-saw-1-400mm-guide-rail-230v","title":"Festool TS 60 KEBQ-Plus-FS Plunge Saw \u0026 1,400mm Guide Rail 230V","description":"\u003cp\u003eThe combination of Festool’s TS 60 plunge saw and the Festool 1,400mm Guide Rail creates a superb system for cutting sheet material with spot-on accuracy.\u003c\/p\u003e\u003cp\u003eThe TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. A unique anti kickback system, protects you from injury and damage to your work. A transparent sliding viewing window and additional markings provide a view of the blade’s start and end point, prior to making a plunge cut. Dust extraction is highly effective when connected to a suitable extractor. With the latest generation brushless EC-TEC motor, the TS 60 is compact, virtually maintenance-free and powerful. Fitted with a thin kerf saw blade, the high speed 6,800 rpm EC-TEC motor ensures quick results.\u003c\/p\u003e\u003cp\u003eThe TS 60 is fully compatible with Festool FS guide rails and FSK cross cut rails, offering 57mm cutting depth with rail fitted.\u003c\/p\u003e\u003cp\u003eThe guide rail has two PTFE strips to allow the saw tool to glide smoothly on the rail. On the underside of the rail there are two neoprene strips, which prevent slippage. There is also a special rubber strip on the underside which is used to minimise splintering on the top surface.\u003c\/p\u003e\u003cp\u003eThe TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. Supplied with a 1,400mm guide rail the TS60 can also be attached to the optional cross cut rails. Blade supplied is a 168mm x 1.8kerf x 20mm bore with 42 Teeth.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54255669936475,"sku":"720834","price":749.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720834_xl_deb26266-0d07-438f-b265-c3b4065c5d92.jpg?v=1791242254","url":"https:\/\/www.axminstertools.com\/products\/festool-ts-60-kebq-plus-fs-plunge-saw-1-400mm-guide-rail-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
