{"product_id":"festool-ts-60-kebq-plus-plunge-saw-230v","title":"Festool TS 60 KEBQ-Plus Plunge Saw 230V","description":"\u003cp\u003eFestool’s TS 60 plunge saw sets new standards in performance and safety. The TS 60 offers a massive maximum depth of cut of 62mm, even when used with a guide rail, you still have 57mm. A unique anti kickback system, protects you from injury and damage to your work. The kickback stop can be manually deactivated, when working without a guide rail on uneven material. The kickback stop is automatically reactivated the next time the saw is switched on. This saw combines precision, flexibility and high performance with enhanced safety.\u003c\/p\u003e\u003cp\u003eWith the latest generation brushless EC-TEC motor, the TS 60 is compact, virtually maintenance-free and powerful. Fitted with a thin kerf saw blade, the high speed 6,800 rpm EC-TEC motor ensures quick results.\u003c\/p\u003e\u003cp\u003eThe TS 60 is easy to operate and precise. Accurate bevel cuts can be made at angles from -1\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to +47\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. Depth of cut with a dual indicator and fine adjustment guarantees exact setting. A transparent sliding viewing window and additional markings provide a view of the blade’s start and end point, prior to making a plunge cut. Dust extraction is highly effective when connected to a suitable extractor. The viewing window can be lowered for virtually dust free working.\u003c\/p\u003e\u003cp\u003eThe FastFix spindle stop makes it extremely easy to change the saw blade. The slimline blade housing allows cutting up to a wall as close as 12mm.\u003c\/p\u003e\u003cp\u003eThe TS 60 can be combined with the FS standard rail system and the FSK cross-cutting guide rail, forming a portable and easy-to-use compound mitre saw system.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118466355547,"sku":"109076","price":629.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109076_xl.jpg?v=1789781227","url":"https:\/\/www.axminstertools.com\/products\/festool-ts-60-kebq-plus-plunge-saw-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
