Power and performance in a compact cordless tool, add in the high build quality and long service life and you have the Festool TXS 18. The power is provided by a Festool 18V battery, combined with the maintenance free brushless E-Tec motor gives you unrivalled performance (note this is a body only tool).
As with all Festool tools every aspect has been designed to ensure you have full control. The TXS 18 is designed for everyday use for light to medium screwdriving and drilling applications. The power, low weight and impressive ergonomics make drilling and fastening almost effortless. The TXS 18 will bore a 35mm hole with a Forstner bit or drive a 6 x 240mm screw into softwood.
The FastFix interface makes the TXS 18 fully compatible with the full range of Festool FastFix attachments, offering great potential. In addition, 1/4 hex bits can be inserted directly into the FastFix spindle for screwdriving or drilling in cramped spaces. The TXS 18 comes equipped with an LED light for working in those cramped dark corners.
A practical integrated bit holder provides storage space for 1/4 hex bits, magnetically secured to prevent them falling out
Supplied with: FastFix keyless chuck 10 mm, belt clip, Systainer SYS3 M 187.
Note: this is a body only tool supplied without batteries or charger.
Battery Voltage 18 V
Rating Trade/Professional
Reverse No
Sound Power Level LwA [Uncertainty K] 83 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 1 mm to 10 mm
Chuck Type keyless
Sound Pressure Level LpA [Uncertainty K] 72 dB(A) [3.0 dB]
Manufacturer Part Number 577287
Web Attribute Set Cordless Drill Drivers
EAN Barcode 4014549404720
