Festool’s UG CSC SYS provides the mobile professional with three main benefits. It’s a heavy duty trolley with large diameter wheels, allowing you to effortlessly move a stack of Systainers of up to 80kg around a site. It turns into a firm and stable work table 580 x 580mm, with a comfortable working height. A grid of holes on the worktop allows you to use clamps etc.
The UG CSC SYS really comes into its own when combined with the Festool CSC SYS 50 cordless table saw. The combo provides the required stability. The legs have adjustment to compensate for any unevenness in the floor. The trolley’s base plate is the same height as the saw and now forms a useful support when ripping long workpieces. With the legs deployed, the working height is 677mm (900mm with the saw fitted). Alternatively, in cases where working closer to the ground is preferable, such as floor laying, with the legs folded in the working height is 245mm.
Load Capacity: as a trolley: 80kg, as a worktable: 100kg
Nett Weight: 18.13kg
Overall L x W x H 1,067 mm x 580 mm x 245 mm
Manufacturer Part Number 577001
Web Attribute Set Saw Bench Accessories
EAN Barcode 4014549391037
