{"product_id":"fisch-25-piece-hss-brad-point-drill-bit-set","title":"FISCH 25 Piece HSS Brad Point Drill Bit Set","description":"\u003cp\u003eThe 25-piece HSS drill from FISCH\u003cspecial id=\"9\"\u003e\u003c\/special\u003e is suitable for drilling into hard and soft wood, MDF and other manufactured boards. They have a precision ground point with twin cutting spurs for precise positioning and a clean cut. Made of very resistant high speed steel to EN ISO 4957 with a hardness of approximately 62 HRC, these drills give you very good and precise results. Their cylindrical shanks allow their use in all common battery operated and hand-held drilling machines as well as in vertical and bench drilling machines. The drill set covers a diameter range from 1 to 13mm in 0.5mm steps. Sizes 1mm to 2.5mm are standard twist drills, with 3mm to 13mm being brad point drills.\u003c\/p\u003e","brand":"Fisch","offers":[{"title":"Default Title","offer_id":54118190580059,"sku":"102530","price":79.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/102530_xl.jpg?v=1789772054","url":"https:\/\/www.axminstertools.com\/products\/fisch-25-piece-hss-brad-point-drill-bit-set","provider":"Axminster Tools","version":"1.0","type":"link"}
