The fast 4-spiral design guarantees rapid and precise results in any type of soft, hard or laminated wood. The Fisch Speed Cut auger cuts faster and cleaner than a traditional flat bit. The full screw-point tip is self-feeding for effortless drilling. Four cutting spurs, 4 cutting edges and 4 spirals ensure rapid removal of the waste. The 1/4 hex shank provides non-slip grip in a drill chuck or use in a quick-change system. The Speed Cut augers are 150mm long overall; the set includes a 150mm extension allowing drilling at great depths.
This set is ideal for joiners, carpenters and anyone carrying out installations or renovations on site. The set consists of 5 auger bits: 14, 16, 18, 20 and 22mm, and a 150mm extension with 1/4 hex socket and shank.
Additional Accessories No
Web Attribute Set Power Auger Bits
EAN Barcode 9002696338420
