235 mm long auger bits of the highest quality, made by FISCH in Austria. They feature 1/4 hex shanks enabling you to use them in a 1/4 hex quick change chuck or for a non slip grip in a keyless drill chuck. Suitable for soft and hard wood. A deep gullet rapidly clears the waste and the threaded tip helps pull the auger into the timber for a fast, clean cut. The auger bit is ground out of one piece of steel to ensure precision with high accuracy to give a long working life. Shanks tempered to DIN 3126-E6,3. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 6.0 mm
Overall Length \ Working Length 235 mm 165 mm
Drill Bit Length 235 mm
Web Attribute Set Power Auger Bits
EAN Barcode 9002696296836
