These HSS drill bits from FISCH are suitable for drilling into hard and soft wood, MDF and other manufactured boards. They have a precision ground point with twin cutting spurs for precise positioning and a clean cut. Made of very resistant, high speed steel to EN ISO 4957 with a hardness of approximately 62 HRC, these drills give you very good, precise results. Their cylindrical shanks allow their use in all common battery operated and hand-held drilling machines as well as in vertical and bench drilling machines.
Choose from 10 different sizes, from 3mm to 8mm in 0.5mm steps and 10mm and 12mm. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 3.0 mm
Overall Length \ Working Length 61 mm 33 mm
Web Attribute Set Wood Boring Bits
EAN Barcode 9002696375043
