Fisch
FISCH Multi-Function Wave Cutter with Centring Tip
SKU: 105933
£20.68
£17.23 Excl. VAT
  • For precise inclined drilling even at extreme angles
  • Centre point acts as pilot for precise positioning
  • Easy placement on marked entry point, no guessing
  • 'Wave' style cutting edge for clean flat-bottomed holes
  • Unrivalled for strength, accuracy and sharpness
  • Guaranteed clean sided holes in hard or softwood
  • Exchangeable tip: centring point or pilot drill
  • Made in Austria
Rather than a solid centre point, these bits feature a replaceable centring tip (an exchangeable 4mm pilot drill is available). These Forstner bits cut particularly easily and produce exact tear-free, holes with smooth walls in softwood and hardwood. FISCH forge their multi-functional bits from a single billet, before being CNC ground and then hardened. Accuracy and sharpness are of the highest level. The unique serrated 'Wave' edge produces extremely clean entry holes, allows faster cutting speeds and requires less effort to bore each hole. The shank has 3 flats for secure chucking in a 3-jaw chuck. Spare drill bits are available as are centre tips for drilling blind or straight through holes. These bits are 90mm long overall excluding the pilot drill. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 20 mm
Web Attribute Set Forstner & Sawtooth Cutters
EAN Barcode 9002696337904
