Celebrate precision drilling with the Fisch Wave Forstner 80 Year Anniversary Set, an 11‑piece metric collection delivering exceptionally clean, accurate holes with reduced vibration for use on hardwoods, softwoods, veneered boards and sheet materials. Featuring the same proven Wave Cutter geometry as the UJK Wave Forstner cutters, this limited‑edition set showcases Fisch craftsmanship in a premium, workshop‑ready format.
Designed for high‑quality woodworking applications, this set includes 11 Wave Forstner cutters covering the most frequently used sizes for cabinetry, furniture making and joinery work. Supplied in a durable Systainer, the cutters are securely stored, clearly organised and well protected for everyday workshop use.
Fisch has been manufacturing cutting tools for 80 years, building a reputation for precision engineering, durability and consistent results on a wide range of wood‑based materials. This anniversary edition celebrates that heritage, combining modern Wave Cutter design with Fisch’s proven production quality.
Supplied as an 11‑piece metric Wave Forstner cutter set covering Ø 15mm, 16mm, 19mm, 20mm, 22mm, 25mm, 30mm, 35mm, 40mm, 42mm and 45mm, presented in a robust Systainer as a special 80 Year Anniversary Edition.
Web Attribute Set Forstner & Sawtooth Cutters
EAN Barcode 9002696401322
