Fiskars
Fiskars IsoCore Pick 2.27kg (5 lb)
SKU: 113257
€100,00
  • Ideal for breaking up rocky surfaces and tough soil
  • Forged, heat-treated steel head with rust-resistant coating for durability
  • Inseparable riveted head for maximum safety
  • SoftGrip handle with ergonomic design for comfort
  • Strategic grip pattern to prevent blisters
  • IsoCore Shock Control System reduces shock and vibration
The Fiskars IsoCore Pick 2.27kg (5 lb) is perfect for breaking up rocky surfaces like gravel and hardened, dried earth with its pick end, or for use as a hoe when digging in tough soil with its mattock end. The forged, heat-treated steel head is finished with a rust-resistant coating, ensuring durability. The inseparable riveted head will not slide down or snap off, even when swung with maximum force.
The SoftGrip handle is sculpted to fit the natural shape of your hand and features a patent-pending strategic grip pattern with large dimples where fingers rest for maximum grip and small dimples where the palm rests to help prevent blisters. The patented IsoCore Shock Control System absorbs strike shock and vibration, reducing the punishment your body takes by transferring 50% less shock and vibration than wood handles.
Specifications: Head Weight: 2.27kg (5 lb). Overall Length: 914mm.
Web Attribute Set Picks and Mattocks
EAN Barcode 6411501560094
