{"product_id":"fiskars-power-gear-bypass-lopper-pruner-set","title":"Fiskars Power Gear Bypass Lopper \u0026 Pruner Set","description":"\u003cp\u003eThe Fiskars PowerGear™ Bypass Loppers Large L78 and the Fiskars SingleStep™ P26 Bypass Pruner secateurs together offer a versatile cutting solution for gardeners tackling everything from light pruning to heavy-duty branch work.\u003c\/p\u003e\u003cp\u003eThe Fiskars PowerGear™ Bypass Loppers L78 are engineered for demanding cutting of fresh wood. Their unique PowerGear™ mechanism boosts cutting power and distributes force evenly throughout the cut, while PowerStep™ technology allows branches to be cut in one or multiple steps. This reduces strain, minimises discomfort, and enhances the overall ease and enjoyment of gardening. Made from fibreglass‑reinforced polyamide, the loppers are both lightweight and exceptionally strong, and the PTFE‑coated blades ensure reduced friction for smoother cutting.\u003c\/p\u003e\u003cp\u003eL78 Specifications\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Cutting Capacity: 50 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Overall Length: 692 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Weight: 1060 g\u003c\/p\u003e\u003cp\u003eComplementing the loppers, the Fiskars SingleStep™ P26 Bypass Pruner is ideal for everyday pruning tasks. Designed for cutting fresh wood, it features a bypass cutting action for clean, precise cuts. The sturdy handles provide a comfortable, secure grip, while the well-balanced design supports steady, controlled pruning. Its carbon steel blades, complete with a non-stick PTFE coating on the upper blade, reduce friction and make both cutting and cleaning easier.\u003c\/p\u003e\u003cp\u003eP26 Specifications\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Cutting Capacity: 22 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Length: 208 mm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Weight: 200 g\u003c\/p\u003e","brand":"Fiskars","offers":[{"title":"Default Title","offer_id":54118840238427,"sku":"114104","price":53.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114104_xl.jpg?v=1789793069","url":"https:\/\/www.axminstertools.com\/products\/fiskars-power-gear-bypass-lopper-pruner-set","provider":"Axminster Tools","version":"1.0","type":"link"}
