Fiskars
Fiskars Power Gear Bypass Lopper & Pruner Set
SKU: 114104
€53,00
  • L78 loppers boost cutting power and reduce strain
  • Lightweight, durable build with low‑friction PTFE blades
  • Lopper capacity 50 mm; 692 mm length; 1,060 g
  • P26 pruner secateurs makes clean cuts on fresh wood
  • Pruner secateurs capacity 22 mm; 208 mm length; 200 g N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
The Fiskars PowerGear™ Bypass Loppers Large L78 and the Fiskars SingleStep™ P26 Bypass Pruner secateurs together offer a versatile cutting solution for gardeners tackling everything from light pruning to heavy-duty branch work.
The Fiskars PowerGear™ Bypass Loppers L78 are engineered for demanding cutting of fresh wood. Their unique PowerGear™ mechanism boosts cutting power and distributes force evenly throughout the cut, while PowerStep™ technology allows branches to be cut in one or multiple steps. This reduces strain, minimises discomfort, and enhances the overall ease and enjoyment of gardening. Made from fibreglass‑reinforced polyamide, the loppers are both lightweight and exceptionally strong, and the PTFE‑coated blades ensure reduced friction for smoother cutting.
L78 Specifications
Cutting Capacity: 50 mm
Overall Length: 692 mm
Weight: 1060 g
Complementing the loppers, the Fiskars SingleStep™ P26 Bypass Pruner is ideal for everyday pruning tasks. Designed for cutting fresh wood, it features a bypass cutting action for clean, precise cuts. The sturdy handles provide a comfortable, secure grip, while the well-balanced design supports steady, controlled pruning. Its carbon steel blades, complete with a non-stick PTFE coating on the upper blade, reduce friction and make both cutting and cleaning easier.
P26 Specifications
Cutting Capacity: 22 mm
Length: 208 mm
Weight: 200 g
Web Attribute Set Pruning
EAN Barcode 6411501150486
