The PowerGear™ Aviation Snip Offset Left Cut 250mm (10in) is designed for precision and ease of use. It features forged, heat-treated steel blades for durability and sharpness. The PowerGear™ technology provides leverage-enhancing gears that give you over 40% more power, especially during the toughest part of the cut. The blade tangs extend to the handles for improved strength and stability. The ergonomic handle, with SoftGrip and strategic texturing, ensures added comfort and control. The EasyAction™ feature automatically opens the handle to help reduce hand fatigue. These snips are ideal for cutting a variety of heavy-duty materials, including sheet metal, ductwork, drywall corners, metal studs, siding, soffit, fascia, drip edge, gutters, and more. Specifications: Length: 250mm (10in). Cut Length: 25.4mm Cutting Capacity: Cuts up to 16-gauge cold-rolled steel (1.518mm) or 20-gauge stainless steel (0.9525mm).
Fiskars
Fiskars PowerGear™ Aviation Snip Offset Left Cut 250mm
| EAN Barcode | 6411501701299 |
