Fiskars
Fiskars PowerGear™ Aviation Snips Straight Cut 250mm
SKU: 113248
€30,00
  • Forged, heat-treated steel blades for durability and sharpness
  • PowerGear™ technology provides over 40% more power
  • Blade tangs extend to handles for improved strength
  • Ergonomic handle with SoftGrip for comfort and control
  • EasyAction™ feature reduces hand fatigue
  • Ideal for cutting a range of heavy-duty materials
The PowerGear™ Aviation Snips Straight Cut 250mm (10in) are designed for precision and ease of use. They feature forged, heat-treated steel blades for durability and sharpness. The PowerGear™ technology provides leverage-enhancing gears that give you over 40% more power, especially during the toughest part of the cut. The blade tangs extend to the handles for improved strength and stability.
The ergonomic handle, with SoftGrip and strategic texturing, ensures added comfort and control. The EasyAction™ feature automatically opens the handle to help reduce hand fatigue. These snips are ideal for cutting a variety of heavy-duty materials, including sheet metal, ductwork, drywall corners, metal studs, siding, soffit, fascia, drip edge, gutters, and more.
Length: 250mm (10in)
Cut Length: 25.4mm
Cutting Capacity: Cuts up to 16-gauge cold-rolled steel (1.518mm) or 20-gauge stainless steel (0.9525mm)
Length 250 mm
Web Attribute Set Snips
EAN Barcode 6411501701251
