Fiskars
FISKARS Solid™ A26 Splitting Axe 2.5kg (5.5 lb)
SKU: 113296
€60,00
  • Safest, undetachable axe head and shaft connection for maximum safety
  • Superior blade design ensures guaranteed sharpness
  • Antifriction coating for easy penetration into the wood
  • Ultralight and durable FiberComp™ shaft minimises fatigue
  • Perfect weight balance for a safe, comfortable, and efficient swing N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
The Fiskars Solid™ A26 Splitting Axe is engineered to deliver powerful, efficient performance when splitting large logs where control, force and reliability matter most. Designed specifically for logs up to Ø30 cm, its robust splitting head drives deeply into the wood, while the superior blade geometry ensures clean, effective splits with every strike. The antifriction blade coating reduces resistance and helps the blade glide smoothly into the log, making each swing more productive and less fatiguing.
Built with safety and durability at the forefront, the Solid™ A26 features Fiskars’ safest, undetachable head‑to‑shaft connection, ensuring absolute security during demanding splitting tasks. The ultralight FiberComp™ shaft is virtually unbreakable and designed to minimise fatigue, even during extended sessions. With perfectly balanced weight distribution between the head and shaft, the axe delivers maximum power transfer while maintaining comfortable, controlled handling throughout every swing.
With over 375 years of design heritage, Fiskars is recognised worldwide for crafting dependable, high‑performance tools that combine precision, comfort and lasting durability. The Solid™ series reflects this commitment, offering tools that stand up to heavy use while remaining easy and enjoyable to handle.
The Fiskars Solid™ A26 Splitting Axe is ideal for splitting large logs for firewood, log‑pile preparation and managing heavier timber around the garden or woodland. Its combination of strength, ergonomic design and long‑lasting build quality makes it an essential tool for frequent wood‑splitting tasks.
Looking for a different size or splitting power? Explore the full Fiskars axe range for smaller, larger, and extra‑powerful options.
Length: 915 mm
Weight: 2.5 kg (5.5 lb)
Web Attribute Set Axes & Adzes
EAN Barcode 6411501310804
