Fiskars
Fiskars X24 Universal Axe
SKU: 113943
€61,00
  • For felling trees and general chopping; thin blade for clean cuts
  • Forged steel blade with sharp edge and rust-resistant coating
  • Secure head-to-shaft connection; ultralight, durable FiberComp™ shaft
  • Balanced design with SoftGrip™ handle and hooked end for safety
  • Includes sheath; 25-year warranty; made in Finland N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
The Fiskars X24 Universal Axe is designed to deliver precise, efficient performance across a wide range of felling and general chopping tasks. Its thin, wide blade edge is optimised for cutting into fresh, resinous woods such as spruce and pine, allowing it to penetrate smoothly and make clean, controlled cuts. The advanced blade‑grinding geometry creates a razor‑sharp edge for superior contact and effortless cutting, while the double‑hardened, forged steel blade maintains sharpness for longer. A low‑friction coating minimises resistance during each strike and provides added protection against rust.
Built for safety, durability and consistent performance, the X24 features a secure, undetachable head‑to‑shaft connection for complete confidence during demanding use. The ultralight FiberComp™ shaft is virtually unbreakable and delivers exceptional overstrike protection, while its perfectly balanced weight distribution helps maximise power with every swing. The oversized SoftGrip™ handle, complete with strategic texturing, enhances comfort and grip, and the hooked end provides additional security for controlled, accurate cutting.
With more than 375 years of cutting expertise, Fiskars is globally recognised for designing tools that combine superior performance with ergonomic excellence. Designed in Billnäs, Finland, the X24 Universal Axe reflects Fiskars’ longstanding commitment to producing durable, high‑quality tools trusted by professionals, woodland workers and homeowners alike.
The Fiskars X24 Universal Axe is ideal for felling small to medium trees, chopping fresh softwoods, trimming branches, and carrying out versatile outdoor cutting tasks.
Looking for a different size or splitting power? Explore the full Fiskars axe range for smaller, larger, and extra‑powerful options.
It includes a protective sheath for safe storage and is backed by a 25‑year warranty.
Length: 600 mm (24)
Web Attribute Set Axes & Adzes
EAN Barcode 6411501201638
