This double-sided block utilises quick change hook and loop backed abrasives. A dual foam block 70 x 125mm with medium density foam one side and soft on the other side for sanding gently curving surfaces. An excellent and useful addition to the job of hand sanding and quite economical as the abrasive can be peeled off and re-used at a later date.
Flexipads World Class
Flexipads Dual Foam Hand Sanding Block 70 x 125mm
| Overall L x W x H | 125 mm x 70 mm x 30 mm |
| Pack Quantity | 1 |
| Web Attribute Set | Hand Sanding Blocks |
| EAN Barcode | 5021526560057 |
