Soft shaped sanding block utilise 70 x 125mm quick change hook and loop backed abrasives. Extremely comfortable to hold and excellent for sanding both flat or gently contoured surfaces. Very convenient for hand sanding as you can quickly swap abrasives as you work through the grit types.
Overall L x W x H 125 mm x 70 mm x 30 mm
Web Attribute Set Hand Sanding Blocks
EAN Barcode 5021526560101
